View the OSPF area information.
View the OSPF area information:
Switch:1>enable Switch:1#show ip ospf area ============================================================================================================================================ OSPF Area - GlobalRouter ============================================================================================================================================ AREA_ID STUB_AREA NSSA IMPORT_SUM ACTIVE_IFCNT NSSA TRANSLATOR NSSA TRANSLATOR NSSA TRANSLATOR NSSA TRANSLATOR ROLE STATE STABILITY INTERVAL EVENTS -------------------------------------------------------------------------------------------------------------------------------------------- 0.0.0.0 false false true 0 candidate disabled 40 0 STUB_COST INTRA_AREA_SPF_RUNS BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT LSACK_SUM -------------------------------------------------------------------------------------------------------------------------------------------- 0 0 0 0 0 0
Variable definitions
The following table defines parameters for the show ip ospf area command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
